Forum > Autohifi > BMW Radio-pripojeni?
 o Navštíveno 6696x o
o 03.04.2008, 15:06 | Kapka (M)
braska ma ve svem BMW tohle origo radio...je k tomu vzadu changer a navigace.. dokazal by nekdo vymyslet jak k nemu pripojit dalsi audio vstup?potrebuju k tomu pichnout audio signal z DVD...
foto k příspěvku  od Kapka
o 03.04.2008, 15:07 | Kapka (M)
ze zadu to ma jenom jejich origo konektor..nic vic...radio nechce menit..kvuli zacleneni do interieru a navigaci...
o 03.04.2008, 15:09 | Kapka (M) | Upraveno: 2008-04-03 15:11:23
zkouseli jsme i takovy ten debilni adapter kazeta s vystupem..ale to se neda..je to strasne nekvalitni...klidne i kdyby nekdo to radio otevrel,postoural se v nem..a treba misto TAPE by vytahnul dozadu cince..klidne se muze zrusit kazeta..neni problem...neco takoveho jste nikdo nedelal? na radiu jsou tyhle kody..
o 03.04.2008, 15:47 | Kapka (M)
o 03.04.2008, 15:48 | Kapka (M)
o 04.04.2008, 11:08 | Kapka (M)
nasel jsem tohle..ale nevim jestli bude fungovat.. a jaky typ..mate nekdo zkusenost?
o 04.04.2008, 11:10 | whiskadelic
zavolej do [ Link ]
o 04.04.2008, 22:25 | texmur0
kapko stačí?
Grey ½ of connector
Pin # 13 / Tweeter Rear Right door + * Yellow Pin # 21 / Tweeter Rear Right door - *Blue / yellow
Pin # 12 / Tweeter Front Right - Blue / Brown Pin #20 / no connection
Pin # 11 / Tweeter Front Right + Blue / black Pin #19 / no connection
Pin # 10 / Switched +12v remote turn on White Pin #18 / no connection
Pin # 9 / Head unit output Front Right + Blue / red Pin #17 / Head unit output Front Right - Brown / orange
Pin # 8 / Head unit output Rear Right + Blue / black Pin #16 / Head unit output Rear Right - Brown / orange
Pin # 7 / no connection Pin #15 / no connection
Pin # 6 / no connection Pin #14 / no connection
Pin # 5 / +12v factory amp +12v supply *Red / green
Pin # 4 / Woofer Front Left +Blue / white
Pin # 3 / Woofer Front Left -Blue / brown
Pin # 2 / Woofer Rear Left +Yellow
Pin # 1 / Woofer Rear Left -Brown
Black ½ of connector
Pin # 34 / Tweeter Front Left - Yellow / brown Pin # 42 / Mid Front Right door + *Green
Pin # 33 / Tweeter Front Left + Yellow / red Pin #41 / Mid Front Right door - *Blue / green
Pin # 32 / Tweeter Rear left door - * Yellow / brown Pin #40 / Mid Front left door + *White
Pin # 31 / Tweeter Rear Left door + * Yellow / black Pin #39 / Mid Front left door - *Blue / white
Pin # 30 / Head output Front left - Brown / orange Pin #38 / Head output Front Left + Yellow / red
Pin # 29 / Head output Rear Left - Brown / orange Pin #37 / Head output Rear Left + Yellow / black
Pin # 28 / no connection Pin #36 / no connection
Pin # 27 / no connection Pin #35 / no connection
Pin # 26 / DC ground factory ampBrown
Pin # 25 / Woofer Rear Right +Blue
Pin # 24 / Woofer Rear Right -Brown
Pin # 23 / Woofer Front Right +Blue / Red
Pin # 22 / Woofer Front Right -Blue / Brown
o 08.04.2008, 20:32 | texmur0
to Kapka:
pošli mi pžesně typ auta a jaký typ rádia tam je zjistím ti kde by se dalo píchnout na výstup
o 09.04.2008, 14:09 | Kapka (M)
je to BMW 328i Coupe rok 99..typ radia jak je na fotce...nevim jak se to presne znaci...
o 09.04.2008, 21:07 | texmur0
tak tady je k rádiu obecný pokec - to se může hodit :-)
Navigation system with radio navigation
Function
The receiver of the GPS satellite navigation system supplies the navigation computer with the current vehicle position in degrees latitude and longitude.
A CD with map data is loaded in the CD drive of the navigation computer. The navigation computer combines the vehicle position calculated by the GPS with this map data.
The driver can enter a destination. The navigation computer calculates a route from the current location to this destination based on selectable criteria (main trunk roads, shortest distance, etc.).
With the aid of arrow indicators and distance data on the navigation radio and a voice output function, the navigation computer indicates how and where to get into the correct lane or turn off while the vehicle is moving.
The navigation computer calculates the distance covered from the signals from an ABS wheel speed sensor.
An inertia sensor, known as the ”GYRO”, informs the navigation computer about rotary movements of the vehicle (e.g. when turning off etc.). This gyro sensor is fitted in the casing of the navigation computer.
The magnetic-field probe familiar from navigation system 1 is eliminated and replaced by the gyro sensor.
An alternative route is recalculated automatically if the driver does not follow the route instructions.
Components
Navigation computer incl. CD drive and gyro sensor
A CD drive is integrated in the navigation computer. The navigation CD is loaded in this drive.
The navigation computer also features a fan. If the cooling capacity of the fan is not sufficient, the navigation computer is switched off due to overheating.
The gyro sensor is an inertia sensor which records the forces which occur during a change in direction and transfers this data to the navigation computer in the form of a voltage change. This gyro sensor is fitted in the casing of the navigation computer.
GPS
The Global Positioning System is a system which was originally developed for military use, in which approx. 20 satellites in earth orbit send position-related signals. These signals are evaluated by a computer specially developed for this purpose and converted into a position. The accuracy of the system varies, however, it is at least within 20 m.
GPS reception is only possible when unobstructed view of the sky is ensured.
GPS, in conjunction with the BMW navigation system, consists of an aerial and a receiver which evaluates the satellite data received via the aerial and transfers the calculated vehicle position to the navigation computer.
Wheel speed sensor
The navigation computer evaluates the signals of an ABS speed sensor (E46 and E52, rear left wheel) and uses this to determine the distance driven.
Navigation CD
The data the navigation computer requires for route planning is stored on the navigation CD. It is advisable to use the latest updated version in order to take account of any changes in the road system.
The navigation system can only be selected if a navigation CD has been inserted in the drive.
AF lines
The acoustic signals are transferred via 2 AF lines directly to the radio.
NAV-bus
The display data is routed via the NAV bus to the LC display.
The user interface, i.e. the menus on the LC display, is set up by the navigation computer.
The navigation system in the workshop
Loading the operating software
A new version of the operating software offered by BMW should be loaded as follows (refer also to instructions on the CD):
Switch on terminal R and wait until the navigation system is ready for operation. Ensure there is a stable voltage supply.
Remove the navigation CD from navigation computer.
Insert software CD in navigation computer.
The loading procedure is shown on the LC display.
Once the loading procedure is completed, first remove the software CD and then confirm the end of the loading procedure by pressing the rotary push button on the operating unit.
Important
Do not change the terminal setting during the loading procedure! Ensure adequate voltage in the vehicle electrical system.
Notes on replacing the navigation computer
Installation
Proceed as described below to install the navigation computer:
Ignition lock in position 0
Connect navigation computer to vehicle wiring harness
Insert navigation computer in retaining fixture
Ignition lock still in position 0
Close all doors and flaps on the vehicle.
Wait approx. 2 minutes (K-bus reset)
The vehicle must not be moved or be subject to vibration during this waiting period.
Reason:
Every time the navigation computer is restarted, it recalibrates its gyro sensor (inertia sensor). The gyro reacts to any movement. This means that the first calibration, which takes place during insertion of the computer in the bracket, leads to defective values.
For this reason, the navigation computer - even before the vehicle moves - has to be made to run a new gyro calibration. This takes place by resetting the K bus as described above.
Coding of navigation computer
The operating software must be loaded first prior to encoding the navigation computer
Initialization may also be necessary on vehicles with BMW Assist
After the navigation computer has been replaced, a test drive lasting approx. 15 minutes is necessary, during which GPS reception must be ensured.
Navigation computer variants
Navigation computer MK2
In the navigation computer MK2, the GPS receiver is installed in a separate housing.
Navigation computer MK3 and MK4
In the case of navigation computers MK3 and MK4, the GPS receiver is integrated in the navigation computer.
Variants or radio navigation
Radio navigation control panel (E46)
Components
On-board monitor radio
Multi-information radio (MIR, E46 and E52)
In the E52, the MIR is fitted without the cassette component.
In the E46, the MIR is fitted with the cassette component.
Components
Multi Information Radio
The MIR consists of the radio component and an operating unit integrated into one device. Two diagnosis addresses are provided for diagnosis purposes so that the radio and operating unit can be diagnosed separately.
o 09.04.2008, 21:13 | texmur0
a toto je výšet možností které v BMW e46 mohli být.
potřebuji přesně vědět kterou máš abych se někam pohl
zdar Tom
foto k příspěvku  od texmur0
Stránka vygenerována za 0.3802 sekund.
