Navštíveno 2564x
25.05.2009, 06:49 |
Bombolino | Upraveno: 2009-05-25 06:50:27
Dostal som ponuka na toto repro a dost o nom uvazujem.
Ma niekto skusenosti s touto znackou alebo s tymto reprom?
Moze mi niekto vypocitat objem tak aby to bolo naladene najnizsie? Dikes
Specifications
Model V-250D2
Size 276mm ( 10" )
Power handling (RMS/Peak)
300/600 W
Nominal impedance
2 x 2 Ohm
Mounting depth
138 mm
Mounting diameter 234 mm
Magnet weight
75 oz
Voice Coil diameter
51 mm ( 2" )
Voice Coil Type/Material
DVC / Black Aluminium
Voice Coils connection series parallel
Impedance 4 Ohm 1 Ohm
Fs
32.1 Hz
32.3 Hz
Vas
31.9 L
32.2 L
Qts
0.465
0.503
Qes
0.513
0.550
Qms
4.457
5.252
Xmax (lin/peak)
10/20 mm
10/20 mm
Re 3.8 Ohm
0.95 Ohm
Mms 122 g
122 g
BL 13.505 TM 6.331 TM
SPL (1W/m) 85.1 dB
85.0 dB
Box suggestions
Closed box
14-24 L
Bass-Reflex box - Car / Hifi
35 L + 3" port / length 25cm
Bass-Reflex box - Car / Loudmusic
28 L + 3" port / length 18cm
REMARK! Subsonic 30Hz
Rozhodujem saaj medzi tymto reprom:
Pioneer TS-W257D2
Pioneer TS-W257D2
Design and Specifications
10” Dual Voice Coil (DVC) Subwoofer for Enclosure applications
1,000 Watts Max. Power Handling350 Watts Nominal Rating
Qts = 0.48
Xmax = 10.4mm
Fs = 37.8 Hz
Vas = 19.1 litres
Frequency Response : 18 ~ 600 Hz.
Efficiency : 87 dB
Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms)Delivered with “jumper link”: ready for 4 Ohm use
f0 (Lowest Resonant Frequency) : 37.8 Hz.Recommended Sealed Enclosure : 18.4 ~ 35.4 Litres
Construction and Materials
Interlaced Kevlar (Aramid Fibre) Reinforced IMPP Cone
3-Layer Fibre Woven Radial Surround
- Dual-layer Urethane + Cotton mesh (Honeycomb pattern)
2.10 Kg Dual-Mass Ferrite Magnet
4-Layer Copper Round Wire Voice Coil
Long Voice Coil Design
Terminal cover with jumper link for 4 Ohm applications
48mm Phenol Resin Coated Glass Cloth
voice coil bobbin with 4 cooling slits
Extended (8mm) and vented pole yoke
Large diameter yellow Conex damper with damper ring
4-Spoke Stamped silver-coated metal basket
Black ABS Magnet Cover
Spring Compression push-type terminals (x4)
Dimensions
Mounting Depth : 143mm
Dimensions : 277 (diam.) x 162mm
6 Mounting Screw Holes
Cutout Opening : 238mm (Diam.)
Mass : 5.7 Kg
Carton : 314 x 191 x 311mm (WxHxD)
Carton Weight : 6.2 Kg
Proč to chceš naladit co nejníž ?
Lebo na DB drag nechcem a chcem poriadny Bass,aj ked je to 10 palec
Co posloucháš, v jakém to bude autě a na jakém zesilovači ?
Pocuvam sem,tam Dance a RNB
Fabia a zosik sa zatial riesi,ale asi nejaky 2 kanal okolo 450 rms mostik.
Ide mi hlavne o RNB
Pioneer som mal 12 palec a slusne tlacil,tak uvazujem nad nim,no SPL Dinamics mi pripada lepsi
Nikto nevie hodit do programu?
vypocitajte mi niekto Pio 10 palec na BR,naladit to nizko
