Forum > Bazar - autohifi > P: HU Clarion DXZ 938 R, 4ch+2ch Hifonics (Zeus, Brutus), repro, inst. mat.
 o Navštíveno 4424x o
o 27.10.2008, 08:11 | Dave0401
Prodam kompletni hifi z meho auta:
1) Clarion DXZ938R ... 6800,-
RDS-EON radio with single play CD deck. CD-R and CD-R/W compatible
Remote control included
- Built in decoder for virtual 5.1 channel Dolby Pro-Logic II system
- Integrated sound adjustment system: AC Processor II with Time Alignment Control and Virtual Space Enhancer control for optimum sound tuning to any car
interior
- Front / Centre / Rear sound channels with adjustable crossover frequencies
- CD text information display
- Auto-sloping, removable front face with case included
- CeNET control system for optional CD changer and multimedia components
- Beat EQ enhancer plus sound control with three band parametric equaliser
- High 4 x 50 Watt maximum power output
- Listen to your mobile phone through radio speakers via selectable 'aux-in' function
- Automatic muting when connected car phone is in use
- Loop-back circuit for optional Dolby Digital and DTS decoder
- Six channel preamp outputs (4.0V) for connecting external amplifier
- Two channel non-fade line outputs with level control
- Adjustable low-pass filter for sub (50 / 80 / 120 / OFF Hz)
- Two RCA type auxiliary inputs for walkman etc.
- High sensitivity RDS/EON radio tuner with 24 preset stations
- Selectable button illumination colour
- Clock display option with auto-setting
- Solid aluminium front panel has dual action motorized opening down to insert CD. Controls accessible with panel in down position
- Functional and attractive colour-highlight control buttons
- Supplied complete with steering-wheel mounted remote control, full installation and operation guide
- Front panel in grey metallic
Pridam 2ks DO. Jeden na volant a jedno klasicke (nove nepouzite - hodnota 600,-)
Podle meho nazoru velice zname radio, vitez mnoha testu.
2) Hifonics Brutus BX 1500D mkII ... 6200,-
- blau beleuchtetes HiFonics Logo
- 24 dB Subsonicfilter 15-35 Hz
- 24 dB Lowpassfilter 35-250 Hz
- Symmetrische Eingänge
- Phase-Shift 0-180°
- variabler Bass-Boost @ 45 Hz, 0 - 18 dB
- Line Outputs
- Bass-Remote
- 1 x 600 / 1000 / 1500 Watt RMS an 4 / 2 / 1 Ohm
- Abmessungen: 264 x 61 x 380 mm
3) Hifonics Zeus ZX 6400 mkII ... 5200,-
- 12 dB Highpassfilter 10-1200 Hz
- 12 dB Lowpassfilter 30-150 Hz
- Bandpass-Funktion schaltbar
- Bass-Boost @ 45 Hz, 0 - 18 dB
- Line Outputs
- Bass-Remote
- 4 x 85 / 170 Watt RMS an 4 / 2 Ohm
- 2 x 340 Watt RMS an 4 Ohm gebrückt
- Abmessungen: 264 x 61 x 382 mm
oba zesiky plne funkcni s krabicemi, navody, Oba zesiky maji sve DO.
Brutus ma lehounky skrabanecek, Zeus top stav.
Myslim, ze tyto kvalitni zesiky neni treba blize predstavovat... ;)
4) PRODANO
5) Hertz HSK 165 s lepsima vyskama (HV 165 + Carpower DT284) ... 3800,-
6) Hertz ESK 165 s lepsima vyskama (EV 165 + Carpower DT284) ... 2800,-
Info k tem vyskam DT284:
Klang + Ton 05/2003
"Even tweeters which are many times more expensive are incapable of doing a better job in most cases, if that good at all."
CAR&HIFI 06/2004
"An absolute insider tip. It is perfectly suitable for installations of high requirement."
autohifi 04/07
TEST WINNER
Absolute top class
Price-performance: * * * * * *
"Excellent purchase value. Best tweeter in the test, the other competitors were clearly beaten."
Dale nabizim:
- Plato je MDF material, potazene, pripravene pro 16ky. Obsahuje box, pro kompa, takze nedochazi k ruseni od SW a je lepsi zvuk stredobasu (hraje v ozvucnici)
- kompletni kabelaz (signaly 4 pary, 2x 35qmm napajeci kabelaz, ANL pojistky v pouzdrech. reprokabely 4qmm a 2,5 qmm atd...)
Staci se ozvat na ICQ nebo mail a muzeme probrat detaily.
DOHODE SE NEBRANIM ;)
foto k příspěvku  od Dave0401
o 27.10.2008, 08:12 | Dave0401
o 27.10.2008, 08:13 | Dave0401
o 29.10.2008, 09:51 | Dave0401
up
o 30.10.2008, 08:23 | Dave0401
aktualni, dohoda samozrejmosti ;)
o 31.10.2008, 12:24 | Kotass
Jak dlouho jsi honil toho Brutuse ? Nějaký vizuální vady "karoserie" ? Záruka ještě je .. ?
o 03.11.2008, 07:17 | Dave0401
Kotass: odpovezeno na ICQ
o 03.11.2008, 07:28 | Kotass
Dave0401: Jáájx .. tam já moc nejsem k zastižení, hoď mi prosím nějaký info na kotass@centrum.cz
Díky moc
o 03.11.2008, 20:29 | mastrojani
ahoj ten zeus je na tom ako? cena je pevná alebo vieme spustiť? vieš mi to poslať aj na slovensko?díky
Stránka vygenerována za 0.3351 sekund.
