Forum > Bazar - autohifi > P: Komplet hifi...
 o Navštíveno 2316x o
o 17.10.2008, 09:52 | Dave0401
Prodam kompletni hifi z meho auta:
1) Clarion DXZ938R ... 7000,-
RDS-EON radio with single play CD deck. CD-R and CD-R/W compatible
Remote control included
- Built in decoder for virtual 5.1 channel Dolby Pro-Logic II system
- Integrated sound adjustment system: AC Processor II with Time Alignment Control and Virtual Space Enhancer control for optimum sound tuning to any car
interior
- Front / Centre / Rear sound channels with adjustable crossover frequencies
- CD text information display
- Auto-sloping, removable front face with case included
- CeNET control system for optional CD changer and multimedia components
- Beat EQ enhancer plus sound control with three band parametric equaliser
- High 4 x 50 Watt maximum power output
- Listen to your mobile phone through radio speakers via selectable 'aux-in' function
- Automatic muting when connected car phone is in use
- Loop-back circuit for optional Dolby Digital and DTS decoder
- Six channel preamp outputs (4.0V) for connecting external amplifier
- Two channel non-fade line outputs with level control
- Adjustable low-pass filter for sub (50 / 80 / 120 / OFF Hz)
- Two RCA type auxiliary inputs for walkman etc.
- High sensitivity RDS/EON radio tuner with 24 preset stations
- Selectable button illumination colour
- Clock display option with auto-setting
- Solid aluminium front panel has dual action motorized opening down to insert CD. Controls accessible with panel in down position
- Functional and attractive colour-highlight control buttons
- Supplied complete with steering-wheel mounted remote control, full installation and operation guide
- Front panel in grey metallic
Pridam 2ks DO. Jeden na volant a jedno klasicke (nove nepouzite - hodnota 600,-)
Podle meho nazoru velice zname radio, vitez mnoha testu.
2) Hifonics Brutus BX 1500D mkII ... 6500,-
- blau beleuchtetes HiFonics Logo
- 24 dB Subsonicfilter 15-35 Hz
- 24 dB Lowpassfilter 35-250 Hz
- Symmetrische Eingänge
- Phase-Shift 0-180°
- variabler Bass-Boost @ 45 Hz, 0 - 18 dB
- Line Outputs
- Bass-Remote
- 1 x 600 / 1000 / 1500 Watt RMS an 4 / 2 / 1 Ohm
- Abmessungen: 264 x 61 x 380 mm
3) Hifonics Zeus ZX 6400 mkII ... 5500,-
- 12 dB Highpassfilter 10-1200 Hz
- 12 dB Lowpassfilter 30-150 Hz
- Bandpass-Funktion schaltbar
- Bass-Boost @ 45 Hz, 0 - 18 dB
- Line Outputs
- Bass-Remote
- 4 x 85 / 170 Watt RMS an 4 / 2 Ohm
- 2 x 340 Watt RMS an 4 Ohm gebrückt
- Abmessungen: 264 x 61 x 382 mm
oba zesiky plne funkcni s krabicemi, navody, Oba zesiky maji sve DO.
Brutus ma lehounky skrabanecek, Zeus top stav.
Myslim, ze tyto kvalitni zesiky neni treba blize predstavovat... ;)
4) Carpower Sonic 12 ... 3500,-
- Impedance (Z): 2 x 2Ω
- Resonant frequency (fs): 27Hz
- Max. frequency range: f3-300Hz
- Music power: 2 x 600WMAX
- Power rating (P): 2 x 350WRMS
- SPL (1W/1m): 85dB
- Suspension compl. (Cms): 0.14mm/N
- Moving mass (Mms): 250g
- Mech. Q factor (Qms): 11.2
- Electr. Q factor (Qes): 0.49
- Total Q factor (Qts): 0.47
- Equivalent volume (Vas): 51 l
- DC resistance (Re): 2 x 1.9Ω/1 x 3.8Ω
- Force factor (BxL): 19Tm
- Voice coil induct. (Le): 2 x 0.7mH/1 x 2.8mH
- Voice coil diameter: Ø 75mm
- Voice coil former: Kapton
- Linear excursion (XMAX): ą25mm
- Eff. cone area (Sd): 511cm2
- Magnet weight: 180oz.
- Weight: 15kg
taky myslim, ze je to velice znamy woofer na AHC ;)
+ pridam lesteny krouzek zdarma
5) Hertz HSK 165 s lepsima vyskama (HV 165 + Carpower DT284) ... 4000,-
6) Hertz ESK 165 s lepsima vyskama (EV 165 + Carpower DT284) ... 3000,-
Info k tem vyskam DT284:
Klang + Ton 05/2003
"Even tweeters which are many times more expensive are incapable of doing a better job in most cases, if that good at all."
CAR&HIFI 06/2004
"An absolute insider tip. It is perfectly suitable for installations of high requirement."
autohifi 04/07
TEST WINNER
Absolute top class
Price-performance: * * * * * *
"Excellent purchase value. Best tweeter in the test, the other competitors were clearly beaten."
Pokud by nekdo mel zajem i o zastavbu do octavie, taky je k dispozici. ... cena dohodou
- Box je MDF 18mm, predni stena 34mm, 2ks BR 100*300mm (vysoce zaoblene), 4 pin konektor pro snadne pripojeni a odpojeni.
- "Dvojite dno" je z DTD, bila barva, modre podsviceni, tvrzene 6mm sklo, zajistena cirkulace vzduchu pomoci 2 tichych vetraku.
- Plato je MDF material, potazene, pripravene pro 16ky. Obsahuje box, pro kompa, takze nedochazi k ruseni od SW a je lepsi zvuk stredobasu (hraje v ozvucnici)
- kompletni kabelaz (signaly 4 pary, 2x 35qmm napajeci kabelaz, ANL pojistky v pouzdrech. reprokabely 4qmm a 2,5 qmm atd...)
Staci se ozvat na ICQ nebo mail a muzeme probrat detaily.
foto k příspěvku  od Dave0401
o 17.10.2008, 09:53 | Dave0401
o 17.10.2008, 09:56 | Dave0401
o 17.10.2008, 17:14 | P3RF3KT
sorry za OT ale tohle je krása! :)
o 17.10.2008, 17:31 | Dave0401
P3RF3KT: Diky ;)
Aktualizace: Sonic a box uz je pryc... Pred chvili si jej odvezl novy majitel s usmevem na tvari :)
o 19.10.2008, 14:18 | Dave0401
Aktual
o 19.10.2008, 14:25 | Dave1984
hraje mu to fakt pěkně a vše je v super stavu :-)
o 21.10.2008, 08:02 | Dave0401
up
o 23.10.2008, 07:22 | Dave0401
up
Stránka vygenerována za 0.3556 sekund.
