Forum > Bazar - autohifi > RE AUDIO 18 SX
 o Navštíveno 902x o
o 19.09.2008, 12:15 | tomee20
Chalanisko ma na predaj tento skvely woofer. je to 18 palec a tak. specifikacia :
SX18-D2 (SX.18.D2/SX18D2) Features:
* Dual Composite 2-piece Cone
* Rubbertek Foam Surround
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3 ” 8-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Triple Stack Magnets
* Progressive Spiders
* Wrap around Rubber Gasket
SX18-D2 (SX.18.D2/SX18D2) Dimensions:
* SX18 18" Dual 2ohm Subwoofer
* Mounting Depth - 9.5”
* Mounting Hole Diameter - 16.75”
* Overall Diameter - 18.5”
* Bolt Hole Circle - 17.5”
* Motor Width - 6.5”
* Motor Depth - 3.25”
* Basket Depth - 6.25”
* Displacement - 0.22 cu. ft.
* Weight - 28 lbs.
SX18-D2 (SX.18.D2/SX18D2) T/S Parameters:
* Electrical Q Value -Qes: 0.53
* Mechanical Q Value -Qms: 6.1
* Total Speaker Q Value -Qts: 0.48
* Free Air Resonance -Fs: 33.2 Hz
* Equivalent Compliance -Vas: 159 liters
* One-Way, Linear Excursion -Xmax: 22 mm
* Efficiency -SPL 1W/1m: 92.7 dB SPL
* Effective Piston Area -Sd: 1210 cm^2
* DC Resistance -Re: 1.9 ohm
* Nominal Impedance -Znom: Dual 2 ohm
* Thermal Power Handling -Pe: 1000 W
* Force Factor -Bl: 21
SX18-D2 (SX.18.D2/SX18D2) Recommended Enclosures:
* Ported Compact: 5.5cf tuned @ 35Hz
* Ported Optimal: 8.0cf tuned @ 34Hz
cena je 12000 tisic SK alebo cca 400 eur :D ked uz dualne zobrazujeme ceny
foto k příspěvku  od tomee20
o 19.09.2008, 12:17 | tomee20
mozno sa da nieco spravit s cenou
kontakt na majitela: icq: 386412783
email: dbdani@azet.sk
o 19.09.2008, 16:44 | db-marek
tomi: ja uz nemam slov na teba, si saleny:), ked ti uz ani to nestaci tak neviem, asi teraz kupis autobus a napchas plny bus takych basakou aby ti stacilo:)sak podla mna sa este ani nerozohral a uz znova predavas.............up:)
o 20.09.2008, 10:20 | mendo
podla znenia inzeratu nemam dojem zeby tomi predaval;-) inak up
o 20.09.2008, 11:29 | tomee20
nevadi bol to moj woofer ;) teraz mam mt cko ktore som este neskusal a kupil by som najradsej xxx ale treba mu strasnu bednu :D
o 20.09.2008, 22:13 | db-marek
tak treba dat vonku sedacky zadne:)
Stránka vygenerována za 0.4506 sekund.
