Forum > Bazar - autohifi > P:D-REX/1202
 o Navštíveno 329x o
o 16.02.2008, 10:49 | DJ.UFÍK
Bez zaruky cena 6500,-
The Legend is Back!
It is available again: the power amplifier from CARPOWER, which deserves to be called D-REX. Even more power capability, more stability, lower noise level, and with features which set standards for a mono subwoofer amplifier.
State-of-the-art car HiFi mono digital power amplifier, 1 x 620WRMS/4Ω, 1 x 1,050WRMS/2Ω
The power amplifier perfectly matched to extreme subwoofer applications. The digital concept with a sensationally high efficiency (low heat generation and highest stability!) provides huge powers for suitable top bass speakers like e.g. the RAPTORs from CARPOWER. It features optimized filters (18dB/oct. or 24dB/oct.) which ensures a perfect sound even at highest volume levels! Var. low-pass, var. subsonic, continuously adjustable phase control, continuously adjustable semiparametric bass boost (var. level + var. frequency!), and gain control 0.3V to 8V with remote control - everything an ultimate bass speaker requires!
An extra special feature e.g. for competitions: the facility to bridge 2 D-Rex/1202 power amplifiers in the link mode provides a power of over 2 kW (RMS power) at 4Ω (the minimum impedance in the link mode)!
Car&HiFi 01/2005: an excellent product
Price/performance: very good
Autohifi 06/2005: rating: top class
"Bass attack! A vicious but enjoyable appearance with perfect features for every application purpose ..."
Technické parametry
Max. power 1,500WMAX
RMS power 2Ω 1 x 1,050WRMS
RMS power 4Ω 1 x 620WRMS
Bridged power 4Ω 1 x >2kWRMS (link mode)
Frequency range 20-150Hz
Load impedance (min.) 2Ω (link mode: 4Ω)
Input sensitivity (line) 0.3-8V/20kΩ
Input sensitivity (high) -
Channel separation -
S/N ratio > 85dB
THD < 0.5%
Low-pass 40-150Hz, 24dB/oct.
High-pass -
Band-pass -
Subsonic 15-50Hz, 18dB/oct.
High EQ -
Low EQ -
Bass boost 30-60Hz, 0dB - (+6dB)
Operating voltage 11-16V DC current /100A
Connections screw terminals
Line 1 x RCA L/R
High input -
Speakers screw terminals
Line 1 x RCA L/R
Remote control RJ45
Admiss. ambient temp. 0-40 °C
Dimensions 300x60x452mm
Weight 6.9kg
Other features Line out HP 80Hz, full range; phase shift
2 x RCA + 1 x RJ45 for link mode
foto k příspěvku  od DJ.UFÍK
o 16.02.2008, 10:57 | DJ.UFÍK | Upraveno: 2008-02-16 10:57:33
Stránka vygenerována za 0.3379 sekund.
