Forum > Bazar - autohifi > P: 2x kompa MBQuart RCE 216 s bonusem
 o Navštíveno 152x o
o 16.06.2007, 13:53 | Shr3k
Prodám dvoje kompa MBQuart Reference RCE 216 á 4000,-, stáří 2 roky. V případě odběru obou setů přidám jako bonus výšky Premium PTE 25 (rok staré), vhodné pro zapojení do aktivu.
foto k příspěvku  od Shr3k
o 16.06.2007, 13:55 | Shr3k
Ještě parametry:
TECHNICAL DATA
Power Handling
60 - 130 W
Impedance
4 ohms
Sensitivity
2,5 W (90 dB/1m)
Frequency Response
38 - 32.000 Hz
Crossover Frequency
4.200 Hz
Crossover Slope
12/12 dB/octave
FEATURES
- The Reference coaxial tweeter support allows for rapid conversion of the component speaker into a coaxial system.
- BBalanced Temperature Technology is used in the tweeter
- Regardless of the wire size or type you can always connect to an MB QUART. Connection types include solder, screw-down, spade or bare wire
- High-grade plastic baskets made from MB QUART's specially formulated polyamide. The baskets utilize DIN standard mounting positions.
- The motor assembly is formed into the basket using an insert molding process.
- A light bulb is incorporated into the crossover networks to extend the life of the tweeter by protecting it against overloading.
- Tweeter with a 19 mm (0.75”) titanium dome and extremely small footprint
- Multi-purpose mounting accessories are included
- Upgrade your midbass with the Add-A-Woofer-System
Výšky:
TECHNICAL DATA
Power Handling
120 W
Impedance
6 ohms
Sensitivity
1,0 W (90 dB/1m)
Crossover Frequency
3.000 Hz
Crossover Slope
18 dB/octave
FEATURES
- Tweeter level can be adjusted in 2dB steps up to -6dB
- Tweeter with a 25 mm (1") titanium dome with a highly elastic butyl rubber surround
Compatible with all Premium speaker systems
o 17.06.2007, 18:21 | Buml
máš mail
o 17.06.2007, 19:25 | Shr3k
Máš odpověď. Na ...@seznam.cz
o 01.07.2007, 20:43 | Shr3k
Prodáno.
Stránka vygenerována za 0.3196 sekund.
