Forum > Bazar - autohifi > P: sadu spickovych zesilovacu
 o Navštíveno 778x o
o 03.01.2007, 12:52 | kral007 (eXtrem-audio.cz) (M)
Prodam zesilovace ESX Quanum - nejvyssi rada, vyrobene v USA pod ZED Audio
mam k tomu i manual, ktery je nesehnatelny
vsechny hodnoty jsou udavane vyrobcem jako RMS a na 12V, namerene hodnoty jsou daleko vyssi jiz pri 12V, vse stabilni do 1ohm (nektere zapojeni umi i 8ohm)
obrovsky pocet moznosti zapojeni, daji se propojovat 2kanaly mezi sebou, 4kanal umi bezet jako monoblok apod...
zakladni udaje:
ESX Quantum Q120.2 - dvoukanal
2*120W / 4ohm
2*190W / 2ohm
1*400W / 4ohm
THD 0,05%
damping factor 300
input 300mV - 18V
unbalanced 2channel 380mV - 9V
balanced TRUE MONO / HI-Voltage 380mV - 22.7V
unbalanced TRUE MONO / HI - Voltage 190mV - 11.4V
LOW pass 50Hz - 4,2KHz @ 12dB/oct
HI-pass 50Hz - 4,2KHz @ 12dB/oct
BASS BOOST variabilni 0 az +18dB / 43Hz
velikost: 73mm * 232mm * 220mm
ESX Quantum Q60.4 ctyrkanal
4*60W / 4ohm
4*90W / 2ohm
2*180W / 4ohm
THD 0,05%
damping factor 200
input 300mV - 16V
unbalanced 2channel 150mV - 8V
balanced TRUE MONO / HI-Voltage 400mV - 21.3V
unbalanced TRUE MONO / HI - Voltage 200mV - 10.6V
LOW pass 15Hz - 1,5KHz @ 12dB/oct
HI-pass 15Hz - 1,5KHz @ 12dB/oct
velikost: 73mm * 232mm * 260mm
ESX Quantum Q475.1 monoblok
1*475W / 4ohm
1*750W / 2ohm
THD 0,05%
damping factor 700
input 300mV - 16V
unbalanced 150mV - 9V
input impedance balanced - 20Kohm minimum
input impedance unbalanced- 10Kohm minimum
Frequency response @1W into 4ohm 7Hz - 200Hz -6dB
Power Response @ rated power into 4ohm 7Hz - 200Hz -6dB
LOW pass 35Hz - 195KHz @ 24dB/oct
HI-pass (subsonic) 7Hz - 42KHz @ 24dB/oct
velikost: 73mm * 232mm * 390mm
takze k prodeji je 2k+4k+1k+1k
cena dohodou nejradeji komplet nebo kombinace 4k+1k a 2k+1k
nabidky posilejte na mail, icq - vse pod nickem
o 03.01.2007, 16:16 | 323Marty
Psal sem ti mail...
o 15.01.2007, 11:56 | Kamilkoo
Kolik za ten ESX Quantum Q475.1 monoblok
Stránka vygenerována za 0.426 sekund.
