Forum > Bazar - autohifi > P: RF zos, sub, Proel RCA, Pure i20, iPod Classic a iné
 o Navštíveno 8263x o
o 12.04.2017, 11:19 | yatsura
Zdravím.
Predám zopár vecí
Repro Audio Development ADW600, kupované tu na fóre s výhybkami a výškačmi Hertz 120€
RCA Proel robené v hifole 2páry po 5m 60€
RCA oehlbach 2x5m 10€
napajací kábel 35 5+1m nepoužitý 20€
Rockford Fosgate Punch P550.2 Dovezeny z US. Krabica, dialkove.
2-channel car amplifier
150 watts RMS x 2 at 4 ohms (275 watts RMS x 2 at 2 ohms)
550 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
variable high- and low-pass filters (40-400 Hz, 12 dB per octave)
wired Punch Bass EQ (0-18 dB at 40 Hz)
Focused Mass Heatsink de
removable connector cover
special-design TO-247 MOSFETs run cooler than standard transistors
CEA-2006 compliant
Cena: 140€
Subwoofer Rockford Fosgate Punch P3D212 s krabicou Dovezený z US 90€
Max Power Handling: 1000 Watts
RMS Power Handling: 500 Watts
2-Ohm Dual Voice Coils
Sensitivity: 85db
Frequency Response: 27-250hz
Custom 10-AWG nickel plated push terminals
Extended pole piece and bumped back plate
High excursion Poly-ester surround
High-temp voice coil with spun-laced Nomex reinforcement collar
Kevlar Fiber reinforced semi-pressed paper cone and ABS/Acrylic dustcap
Dual linear spider with embedded 16 AWG tinsel leads
Protective PVC textured magnet cover
Reversible diamond cut cast aluminum trim ring
Vented spider cavity
Works great in sealed or vented enclosures
Trim Ring Diameter: 13"
Trim Ring Height: 1"
Mounting Diameter: 11.25"
Mounting Depth: 6.75"
Weight: 24.5 lbs
Pure i20 dokovacia stanica pre ipod s optickým výstupom kupovaná v septembri 2015, takže ešte v záruke 70€
iPod Classic 160gb 7 gen. 3roky starý s pôvodným balením 100€
Všetko v 100% technickom stave. Optický stav viď foto. Ipod je trochu oťukaný, ale 100% funkčný.
o 12.04.2017, 11:21 | yatsura
foto k příspěvku  od yatsura
o 12.04.2017, 11:23 | yatsura
o 12.04.2017, 11:24 | yatsura
o 12.04.2017, 11:25 | yatsura
o 12.04.2017, 11:26 | yatsura
o 12.04.2017, 11:27 | yatsura
o 12.04.2017, 11:28 | yatsura
o 12.04.2017, 11:29 | yatsura
o 12.04.2017, 11:30 | yatsura
o 12.04.2017, 11:31 | yatsura
o 12.04.2017, 11:32 | yatsura
o 03.06.2017, 23:05 | yatsura | Upraveno: 2017-06-03 23:05:48
RCA Proel 2páry po 5m 40 €
Oelbach 2páry po 5m 8 €
napajací kábel 35 5+1m nepoužitý 15 €
Rockford Fosgate Punch P550.2 120 €
Rockford Fosgate Punch P3D212 80 €
Pure i20 60 €
iPod Classic 160gb 7 gen. 3roky starý s pôvodným balením 80 €
Stránka vygenerována za 0.3427 sekund.
