Prodám 4 kanálový zesilovač Jensen USA XA4150
popis:
Performance
RMS Power Output (Watts x Channels) 75 x 4
Frequency Response 20-20k Hz
THD at Rated RMS Power 0.08%
Signal to Noise Ratio 100 dB
Input Voltage 14.4v
Peak Power Output (Watts x Channels) 150 x 4
Power at 2 Ohms (Watts x Channels) 100 x 4
Bridged Power (Watts x Channels) 200 x 2
Minimum Impedance Bridged 4
Minimum Impedance Unbridged 2
Features
Amplifier Class AB
Tri-Way Capable Yes x 2
Low-Pass Crossover Frequency 40-240 Hz
Low-Pass Slope (dB/octave) 12 dB
High-Pass Crossover Frequency 40-240 Hz
High-Pass Slope (dB/octave) 12 dB
Bass Boost 6 dB
Bass Boost Frequency 45 Hz
Fan Cooled No
Fuse Rating 25 x 2
Speaker Level Inputs Yes
Preamp Outputs 1 pair
LED Power Indicator Yes
Height (inches) 2-5/8
Width (inches) 14
Length (inches) 11-1/8
A sound investment: the Jensen XA4150 amp has all the bells and whistles you'd expect from a top-flight amp at a very affordable price.
Top-mounted controls give you quick and easy access to the high- and low-pass variable crossovers. Gold-plated screw terminals and RCA inputs and outputs ensure optimum signal integrity and corrosion resistance. Preamp outputs make it easy to install multiple amplifiers. Adding the XA4150 to a factory system? Speaker-level inputs make it easy to hook up to any radio
Details:
* 2-, 3-, or 4-channel output
* Tri-way capable (Tri-Way Crossover required)
* 200 watts RMS x 2 bridged output
* 100 watts x 4 at 2 ohms
* requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
* speaker-level inputs
* high- and low-pass crossovers, variable from 40-240 Hz, 12 dB/octave
* 6 dB bass boost at 45 Hz
* preamp outputs
* MOSFET power supplies
* speaker short, thermal overload protection
* 14"W x 2-5/8"H x 11-1/8"D
Super stav, Jako nový !
Cena dohodou.. levně
Kontakt:
ICQ: 348212590
Tel.: 608269933
email: caracass@seznam.cz
