Forum > Bazar - autohifi > Prodám zesilovače monoblok/2kanály/4kanál+ kapik a drobnosti
 o Navštíveno 4940x o
o 19.04.2014, 15:39 | Sisma | Upraveno: 2014-04-19 15:40:53
Monoblok DLS CAD11
Velice kvalitní a dostatečně silný digital monoblok, bez problému stabilní na 1ohm, dálkové ovládání bassboost. Opticky a funkčně 100%.
počet kanálů 1
kmitočtový rozsah 15 - 160 Hz
odstup signál/šum 100 dB
damping factor > 100
výkon 4 Ω RMS 1 x 400 W
2 Ω RMS 1 x 750 W
1 Ω RMS 1050 W
Pojistky 4x30A
Cenovka 5000 Kč.
Dvoukanálový zesilovač Rockford Fosgate Punch 501s
Starý, ale hodně slušný a dost silný zesik od Rockfordu.
• 125 watts RMS x 2 at 4 ohms
• 250 watts RMS x 2 at 2 ohms
• 500 watts RMS x 1 at 4 ohms in bridged mode
• stereo or bridged mono output
• 4-ohm stable in bridged mode
• Tri-Way capable
• requires 8-gauge power and ground leads and a 50-amp fuse — wiring and hardware not included with amplifier
• continuously variable 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
• MOSFET power supply and output devices
• MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
• TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
• Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
• NOMAD — advanced protection circuitry for "intelligent" shutdown protection
• wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
• speaker- and preamp-level inputs
• 12-1/16"W x 2-3/8"H x 9-7/8"D
Cenovka kolem 3000 Kč
Dvoukanálový zesilovač JBL gto75.2
Má nahráno jen pár hodin, opticky i funkčně 100%
Amplifier Output Details 97 Watt - 4 Ohm - THD 1.0% - 2 channel(s) ¦ 145 Watt - 2 Ohm - THD 1.0% - 14.4V DC - 2 channel(s) 1x 290 Watt RMS
Response Bandwidth 10 - 90000 Hz
Signal-To-Noise Ratio 82 dBA
Crossover Slope 12 dB/octave
Low Pass Frequencies 32 - 320 Hz
High Pass Frequencies 32 - 320 Hz
Output Power / Total 260 Watt
Additional Features Input level controls
Amplifier Output 2-channel
Crossover 2-way active crossover
Input Signal Voltage 0.23 - 5.5V
Cenovka 2500 Kč
Čtyřkanálový zesilovač Rodek R480i 4×80 W
Kus železa, který neurazí ani po letech, opticky pár škrábnutí, funkčně 100%
• 4 × 80W / 4 Ohm RMS
• Stabilní do 2 Ohm
• Můstkovatelný na 2 × 250W @ 4 Ohm RMS
• Lowpass filtr 40 ~ 200 Hz
• Hipass filtr 40 ~ 200 Hz
• Low a Hi pass filtry mohou být přemostěny
Z měření vždy vycházel s reálným RMS někde přes 4x90W, je to sice starý, ale velice poctivý zesik se slušným zvukem „za ty prachy“
Cenovka 2000 Kč
Pak tu je 3F kapík Pyle PLDCP3
Je již opticky trochu horší, tmavý chrom je jakoby zoxidovaný, ale funkční 100%
• 3 Farad
• 18V Square Hybrid Capacitor with DCV-AMP
• Double Display
• Line-Flash Blue LEDs
• Silver Aluminum Anodized Square Case
• Chrome Top/Bottom Metal Cover
• Black Chrome Plated Center
• Chrome Plated POS-NEG Power Block
Cenovka 1500
A nakonec nějaké pojistkové pouzdra, rozboč blok a nějaké kabely. Ceny dohodou
Kontakt: Sisma@seznam.cz tel 724644436
Ceny víceméně na dohodu a při odběru víc věcí slevy. Ceny bez poštovného
o 19.04.2014, 15:42 | Sisma
foto k příspěvku  od Sisma
o 19.04.2014, 15:43 | Sisma
o 19.04.2014, 15:44 | Sisma
o 19.04.2014, 15:45 | Sisma
o 19.04.2014, 15:46 | Sisma
o 30.04.2014, 09:50 | Sisma
Mno, co takhle akční týden? Do 5.5. všechny ceny o 500,- nižší. + Speciální sleva dalších 500 při odběru 2 a více věcí..
o 19.05.2014, 15:53 | Sisma
No koukám, že taková krásná cenová akční nabídka nikoho neoslovila, tak kdyby měl někdo nějakou jinou cenovou představu, tak ať se ozve, třeba se dohodneme...
o 23.06.2014, 10:10 | Sisma
Rodek je fuč, zbytek zatím aktuální, kdyby někdo chtěl.. Kabeláž mám už sepsanou a změřenou, mohu poslat seznam..
o 23.06.2014, 11:55 | jodua
vzal bych asi kapacitor. Napis mi na mail kolik bys za nej chtel vcetne posty :D
Diky
o 23.06.2014, 15:04 | Osly
Sisma: co máš za ty napájecí kabely + pouzdro + rozvodnej blok? případně představa o ceně? :)
o 29.06.2014, 15:01 | curky
Nabízím za něj 1500-, bereš?
o 30.06.2014, 10:09 | Sisma
Curky: promiň, ale to je fakt málo. Máš mail..
Jinak pojistkový pouzdra, rozboč blok a něco málo kabelů fuč, zbytek aktuální...
o 30.06.2014, 12:15 | Osly
jj vše došlo v pořádku a bez problému :)
o 03.07.2014, 01:43 | pajaxox
Ahoj v jakém stavu je ten DLS zesilovač? A náhodou ty jističe už nemáš? Případně co ti zbylo za kabely? Dekuji.
o 03.07.2014, 14:08 | Sisma
Ahoj, během chvíle Ti písnu maila..
Stránka vygenerována za 0.3385 sekund.
