Forum > Bazar - autohifi > 5ti kanal zesilova DLS CA 51
 o Navštíveno 6289x o
o 30.04.2013, 08:22 | CervinVega
Prodam SQ 5ti kanal zn. DLS (made in Sweden), perfektni stav opticky i technicky, moznost vyzkouset v aute, original krabice a doklad, zarucak...
CA51 in new design 2012
CA51 in a new exclusive design, but the inside is of the same high quality as before.
This is an amplifier suitable for full in-car entertainment systems. Nominal output of 4 x 50 Watts + 1 x 170 Watts on a mono sub channel.
- Built-in low pass and high pass filters.
- Variablephase shift control on the sub channel.
- Built-in protection circuits shut down the amplifier in the event of overloads.
- High level input with auto start.
-RMS output power @ 13,8 V, 20Hz - 20 kHz
Specifications
Number of channels 5
Amplifier class AB
Mono bridge mode 4 ohm 2 x 150 W RMS
Output power in 2 ohm 4 x 80 W RMS
Output power in 4 ohm 4 x 50 W RMS
Mono sub channel 2 ohm 225 W
Mono sub channel 4 ohm 170 W
Damping factor > 100
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance > 10 kohm
Input impedance, high level 100 ohm
Filters channel A & B HP: 15-500 Hz. LP: 50-500 Hz / 05 - 5 kHz (x10)
Remote bass level control No
Low level output No
Remote phase shift control No
Phase control for subwoofers 0-180 degrees cont. variable
High level input with auto start Yes
Power consumption (idle) 1 A
Power consumption (max) 90 A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 3 x 30 A
Dimension (W x D x H) 250 x 419 x 67 mm / 9,84 x 16,5 x 2,63"
Weight 5,3 kg / 11,7 lb
PC pres 10tis Kc. Velmi vyvazeny a cisty projev. Poslech/odber Praha 6, tel 604 200 794.
Cena 4999,-
o 30.04.2013, 08:25 | CervinVega
vice info/fotek na bazosi: [ Link ]
pripadne jeste levnejsi 5ti kanal Soundstream a subwoofer Xentrix 25cm v dalsich inzeratech... potrebuju se zbavit starych kramu...
o 06.05.2013, 12:15 | CervinVega
Dohoda možná.-)
o 11.08.2013, 12:03 | CervinVega
Aktual, lezi mi v krabici na půdě, super čistý a příjemný zvuk...
o 19.06.2014, 09:36 | CervinVega
3999,-
o 28.08.2015, 14:02 | CervinVega
porad na pude, zacina se tam bat... :-)
o 04.01.2016, 11:03 | CervinVega
pripadne vymenim za lepsi kompaktni 4kanal s HiIn vstupy (staci 4x50 rms), vzajemny doplatek neni problem
Stránka vygenerována za 0.3236 sekund.
