Forum > Bazar - autohifi > P : high-end monoblok DLS A6
 o Navštíveno 1125x o
o 19.01.2011, 16:00 | CRXMen
Prodám high-end monoblok DLS A6.
Output power in 4 ohm 500 W RMS
Output power in 2 ohm 870 W RMS
Output power in 1 ohm 1200 W RMS
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,2 - 7 V
Input impedance, high level N/A
Input impedance > 10 kohm
High pass filter Subsonic: 25 Hz
Low pass filter 50-125 Hz
External cooling fan terminal Yes
Dual DC inputs Yes
Low level output No
Phase control for subwoofers 0- 180 degrees cont. variable
High level input with auto start No
Remote bass level control Yes
Remote phase shift control Yes
Integrated fan Yes
Power consumption (idle) 0,6 A
Power consumption (max) 140 A
Rec. power cable Minimum 2AWG / 33 mm2
Fuses 4 x 35 A
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
Weight 6,2 kg ( 13,67 lb)
Komplet, Cz záruka 24 měs.
Akční cena : 8 490,- (doporučená 17 000,-) [ Link ]
foto k příspěvku  od CRXMen
o 04.02.2011, 10:04 | CRXMen
Prodáno
Stránka vygenerována za 0.4387 sekund.
