Forum > Bazar - autohifi > P: Alphasonik PMA1200-DA
 o Navštíveno 1098x o
o 12.08.2009, 14:32 | luda551 | Upraveno: 2009-08-12 14:34:12
1-CHANNEL CLASS D MONO BLOCK
POWER AMPLIFIER
2400 Watts x 1 @ 1 ohm Mono
2000 Watts x 1 @ 2 ohms Mono
1200 Watts x 1 @ 4 ohms Mono
Dimensions: (W x H x L) 232 x 65 x 530mm
Bridgeable with Second Identical Model
(3’ Modular Cord Included)
Hour Meter (Patent Pending)
Remote Mount Digital Voltmeter (Patent Pending) (included)
Remote Mount Bass Boost Control (included)
Heavy Duty One-piece Extruded Aluminum Heat Sink
Beveled Clear Acrylic Protective Cover
Tiffany-Style Input and Output RCA Jacks
Parallel Line-out RCA Jacks
Removable Covers Conceal Control and Terminal Panels
MOSFET High Speed Switching Power Supply
Milspec Double-Sided Glass Epoxy Circuit Board with Through-hole Plating
Heavy 4 oz. Pure Copper PC Traces at All Preamp and Amplification Stages
Internally Mounted Fan-Cooled Power Supply
Solid Brass Nickel-plated Terminal Blocks (4-gauge Power, 8-gauge Speaker)
Terminal Blocks are Compression Type and Soldered Directly to the PCB
Variable Low Pass Filter: 50Hz~150Hz, 24dB/Octave
Variable Subsonic Filter: 15Hz~40Hz, 24dB/Octave
Variable Bass Boost at 45Hz: 0~+ 18dB
Variable Phase Shift: 0~180 Degrees
THD: 0.05
Signal-to-Noise Ratio: >100dB
Frequency Response: 5Hz~250Hz
Input Impedance: 10K ohms
Input Sensitivity: 300mV~8V
4-Way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset
PMA10B
REMOTE BASS BOOST CONTROL
Backlit Rotary Control Knob in Underdash Case with 16’ cord
PMA100V
REMOTE DIGITAL VOLTMETER
Orange LED Display in Surface Mount Case with 16’ Modular Cord
cena kolem 12t dohoda možná nebo vyměna za neco jineho woofer,zesiky atp...
Stránka vygenerována za 0.311 sekund.
