Forum > Bazar - autohifi > P: 3x Sinfoni zesiky, 4x ESX zesiky by ZED Audio, 2x Kicker EQ + mono, 2x Soundstream
 o Navštíveno 3044x o
o 09.12.2008, 00:02 | kral007 (eXtrem-audio.cz) (M)
prodam tri zesiky
2x Sinfoni AMPLItude 90.2x (s vyhybkou)
1x Sinfoni AMPLItude 90.2 (nema vyhybku)
na zesiky poskytnu 6ti mesicu zaruku
power supply:9-15 VCC
stand-by current <1,2A
input sensitivity 0,4 - 8V
input impedance 48 KOhm
output power:
4ohm @ 12V/14,4V - 72/105W x2
2ohm @ 14,4V - 165W x2
mono 4ohm @ 14,4V - 335W x1
frequency response +/- 1dB from 10Hz to 30KHz
S./Noise ratio >90dB
dimensions 315mm x 187mm x 40mm
weight 3,5kg
POUZE CELOU SADU V CELKU
cenu nabidnete
tel.: 608 73 60 78
mail: kral007[at]centrum.cz
o 09.12.2008, 00:03 | kral007 (eXtrem-audio.cz) (M)
o 09.12.2008, 00:04 | kral007 (eXtrem-audio.cz) (M)
Prodam zesilovace ESX Quanum - nejvyssi rada, vyrobene v USA pod ZED Audio
mam k tomu i manual, ktery je nesehnatelny
vsechny hodnoty jsou udavane vyrobcem jako RMS a na 12V, namerene hodnoty jsou daleko vyssi jiz pri 12V, vse stabilni do 1ohm (nektere zapojeni umi i 8ohm)
obrovsky pocet moznosti zapojeni, daji se propojovat 2kanaly mezi sebou, 4kanal umi bezet jako monoblok apod...
zakladni udaje:
ESX Quantum Q120.2 - dvoukanal
2*120W / 4ohm
2*190W / 2ohm
1*400W / 4ohm
THD 0,05%
damping factor 300
input 300mV - 18V
unbalanced 2channel 380mV - 9V
balanced TRUE MONO / HI-Voltage 380mV - 22.7V
unbalanced TRUE MONO / HI - Voltage 190mV - 11.4V
LOW pass 50Hz - 4,2KHz @ 12dB/oct
HI-pass 50Hz - 4,2KHz @ 12dB/oct
BASS BOOST variabilni 0 az +18dB / 43Hz
velikost: 73mm * 232mm * 220mm
ESX Quantum Q60.4 ctyrkanal
4*60W / 4ohm
4*90W / 2ohm
2*180W / 4ohm
THD 0,05%
damping factor 200
input 300mV - 16V
unbalanced 2channel 150mV - 8V
balanced TRUE MONO / HI-Voltage 400mV - 21.3V
unbalanced TRUE MONO / HI - Voltage 200mV - 10.6V
LOW pass 15Hz - 1,5KHz @ 12dB/oct
HI-pass 15Hz - 1,5KHz @ 12dB/oct
velikost: 73mm * 232mm * 260mm
ESX Quantum Q475.1 monoblok
1*475W / 4ohm
1*750W / 2ohm
THD 0,05%
damping factor 700
input 300mV - 16V
unbalanced 150mV - 9V
input impedance balanced - 20Kohm minimum
input impedance unbalanced- 10Kohm minimum
Frequency response @1W into 4ohm 7Hz - 200Hz -6dB
Power Response @ rated power into 4ohm 7Hz - 200Hz -6dB
LOW pass 35Hz - 195KHz @ 24dB/oct
HI-pass (subsonic) 7Hz - 42KHz @ 24dB/oct
velikost: 73mm * 232mm * 390mm
takze k prodeji je 2k+4k+1k+1k
cenu nabidnete
o 09.12.2008, 00:05 | kral007 (eXtrem-audio.cz) (M)
o 09.12.2008, 00:08 | kral007 (eXtrem-audio.cz) (M)
Kicker KQ30
novy, zabaleny, nepouzity
30pasem nastaveni
vice info na www.kicker.com
manual
tech.info
mam 2kusy
cenu nabidnete
o 09.12.2008, 00:13 | kral007 (eXtrem-audio.cz) (M)
monoblok Kicker ZX400.1
# mono subwoofer amplifier
# 200 watts RMS x 1 at 4 ohms (400 watts x 1 at 2 ohms)
# variable low-pass filter (50-200 Hz at 24 dB per octave)
# variable bass boost (0-18 dB at 40 Hz)
# subsonic filter (12 dB at 25 Hz)
# wired remote bass level control
# Class D design
# CEA-2006 compliant
# speaker-level inputs
# preamp inputs and outputs
# fuse rating: 40A x 1
# 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
# 10-1/4"W x 2-5/16"H x 9-5/8"D
novy zesik
cenu nabidnete
o 09.12.2008, 00:55 | kral007 (eXtrem-audio.cz) (M)
Soundstream Lil´Wonder
2kanal
2*80W RMS
LPF, HPF, Subsonic
mam 2 stejne kousky
fotku asi az zitra
cenu nabidnete
POUZE v CELKU
2kusy
o 17.12.2008, 12:15 | Harby
šlo by se domluvit na ESX Quantum
o 17.12.2008, 15:58 | kral007 (eXtrem-audio.cz) (M)
slo, ozvy se do mailu
Stránka vygenerována za 0.3698 sekund.
