Forum > Vzkazy > for Red Baron - Z28
 o Navštíveno 1570x o
o 25.08.2006, 20:34 | MarauderZ28
Camaro Z28
Eagle Competition 4340 Forged 383ci Stroker Kit
-Eagle 3.750" 4340 Crankshaft
-Eagle 4340 5.700" H-Beam Rods
-SRP Forged Pistons (low compression for boost)
-File Fit Piston Rings
-Clevite Main Bearings
-Clevite Rod Bearings
-Clevite Cams Bearings
-Balanced Assembly
LT-4 Performance Heads
LT-4 Valve Spring
LT-4 Valve - Sodium & Potasium Filled
Comp Pro-Magnum 1.6 Roller Rockers
Bosch 42# Injectors
Holley 58mm TB
Moroso Race Oil Pan w/High Volume Pump and pick-up
Victory Racing Custom Comp Camshaft
Fel Pro LT1 Gasket Pack
Milodon 4 Bolt Main Caps
GM A/C Delete Pulley Bracket
SLP Long Tube Headers
Borla Cat Back
Hypertech Power Programmer III
Granatelli 3,5“ MAF
MSD Racing Power Starter
MSD Spark Plug Wire
K&N Oil Filter
Engine Oil Cooler
Diff Oil Cooler
Trans Oil Cooler
Fluidyne Nascar Radiator
Meziere HD Electric Water Pump
Spal 16“ Fan
Hypertech 160F Thermostat
Powerdyne Supercharger 6,5 PSI @ 12 PSI
Ceramic Bearing Rebuild Kit
Treadstone TM IC
MSD Blaster Coil
MSD 6BTM Ignition Control Box
B&M Oval Air Filter
SLP K-Member Airc. Alu
SLP Upper A-Arms Airc. Alu
SLP Lower Arms Airc. Alu
SLP Lower Arm (zadní)
SLP Sway Bar (F+R)
SLP Panhard Bar
SLP Lower Control Arms Relocation Bracket
SLP 3 Point Subframe Connectors
HOTCHKIS strut bar
Energy Suspension Full Urethane Kit
Edelbrock Torque Arm
Eibach Spring
Bilstein Shock
Vizage Body Kit
Callaway Replica Rear Bumper
WW Wing
Altezza Tail Light
4x Bi-Xenon Head Light
Schmidt Revolution Tune 18“
Brembo 4 Piston Calipers
Zimmermann 315 mm Drilled Rotors
Sandtler Seats
Schroth Belts
Momo Steering Wheel
Hurst Short Shift
Hurst Shift Knob
Plazma Gauges
Stránka vygenerována za 0.3157 sekund.
