Forum > Vzkazy > to Michal ešusák
 o Navštíveno 704x o
o 07.03.2006, 15:52 | clown
hele ..
star systemu ...
pry cisty .. :o))
linuxari deste se .. tohle umi jen amici .. dobrej bordel na to, ze to je jen konsole Apcka
Restarting system.
+Ethernet eth0: MAC address 00:00:84:60:50:02
Can't get BOOTP info for device!
RedBoot(tm) bootstrap and debug environment [ROM]
Red Hat certified release, version 1.92 - built 10:32:13, May 11 2005
Platform: Psion (XScale)
Copyright (C) 2000, 2001, 2002, Red Hat, Inc.
RAM: 0x00000000-0x02000000, 0x0001f960-0x01fd1000 available
FLASH: 0x50000000 - 0x50800000, 64 blocks of 0x00020000 bytes each.
== Executing boot script in 3.000 seconds - enter ^C to abort
RedBoot> fis load kernel
RedBoot> exec
Using base address 0x01600000 and length 0x00092564
Uncompressing Linux......................................... done, booting the k
ernel.
Linux version 2.4.20 (george@purr) (gcc version 3.2.1) #24 Thu Jun 2 10:23:31 PD
T 2005
CPU: Intel XScale-IXP425/IXC1100 revision 1
Machine: Psion 9160
alloc_bootmem_low
memtable_init
Security risk: creating user accessible mapping for 0x60000000 at 0xff00f000
Security risk: creating user accessible mapping for 0x51000000 at 0xf1000000
Security risk: creating user accessible mapping for 0x55000000 at 0xf5000000
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 rootfstype=cramfs
ro ip=off mem=32M@0x00000000
Calibrating delay loop... 263.78 BogoMIPS
Memory: 32MB = 32MB total
Memory: 31004KB available (1054K code, 247K data, 72K init)
XScale Cache/TLB Locking Copyright(c) 2001 MontaVista Software, Inc.
Dentry cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
POSIX conformance testing by UNIFIX
PCI Autoconfig: Found Bus 0, Device 14, Function 0
PCI Autoconfig: BAR 0, Mem, size=0x10000, address=0x4bff0000
PCI: bus0: Fast back to back transfers enabled
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB.
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI en
abled
ttyS00 at 0xff001003 (irq = 13) is a XScale UART
Software Watchdog Timer: 0.05, timer margin: 60 sec
RAMDISK driver initialized: 16 RAM disks of 8096K size 1024 blocksize
loop: loaded (max 8 devices)
Creating 8 MTD partitions on "IXP425 Flash":
0x00000000-0x00060000 : "RedBoot"
0x00060000-0x00160000 : "kernel"
0x00160000-0x00560000 : "rootfs"
0x00560000-0x00660000 : "config"
0x00660000-0x00760000 : "default"
0x00760000-0x007c0000 : "unallocated space"
0x007c0000-0x007c1000 : "RedBoot config"
mtd: partition "RedBoot config" doesn't end on an erase block -- force read-only
0x007e0000-0x00800000 : "FIS directory"
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
ip_conntrack version 2.1 (256 buckets, 2048 max) - 320 bytes per conntrack
ip_tables: (C) 2000-2002 Netfilter core team
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
Bridge firewalling registered
802.1Q VLAN Support v1.7 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com
VFS: Mounted root (cramfs filesystem) readonly.
Freeing init memory: 72K
init started: BusyBox v1.00-pre7 (2005.06.01-00:30+0000) multi-call binary
Starting pid 10, console /dev/console: '/sbin/apconfd'
apconfd: Daemonizing...
apconfd: Daemonized.
LED support initialised
Module init.
ixp425_eth:
Initializing IXP425 NPE Ethernet driver software v. 0.1.9 (patch 20040129) (1_4)
ixp425_eth: CPU clock speed (approx) = 0 MHz
[error] ixEthMiiPhyScan : unexpected Mii PHY ID 0143bc30
ixp425_eth: Error reading MII reg 31 on phy 1
ixp425_eth: eth0 is using the PHY at address 0
ixp425_eth: eth1 is using the PHY at address 1
ixp425_eth: ixEthMiiLinkStatus failed on PHY1.
Can't determine
the auto negotiated parameters. Using default values.
ar5211.c : Atheros AR5211 driver v0.0
ar5211 hwaddr: 00:08:A2:01:0C:3C
ar5211 wlan0.11: Device at 0x4bff0000, IRQ 23
cramfs: wrong magic
apconfd: Completing any configuration upgrades...
/usr/sbin/config-file progress: "loading configuration files..."
/usr/sbin/config-file info: "factory defaults file:"
/usr/sbin/config-file info: "/dev/mtd3"
/usr/sbin/config-file info: "rescue configuration file: /etc/rescueapconfig.xml"
/usr/sbin/config-file progress: "parsing configuration files..."
/usr/sbin/config-file progress: "configuration versions match, migration is not
required"
/usr/sbin/config-file progress: "config-file done."
apconfd: Configuration upgrades complete.
apconfd: Debug level is now 0.
connect: Unknown error 111
ieee802_11_send_deauth: send: Unknown error 100
connect[radius-auth]: Unknown error 101
ioctl(SIOCGIFINDEX): Unknown error 19
wlan0guest: ioctl[PRISM2_IOCTL_PRISM2_PARAM]: Unknown error 19
interface vlan1 does not exist!
kill: Could not kill pid '52': Unknown error 3
interface wlan0wds0 does not exist!
kill: Could not kill pid '73': Unknown error 3
device wlan0 is already a member of a bridge; can't enslave it to bridge br0.
kill: Could not kill pid '94': Unknown error 3
kill: Could not kill pid '117': Unknown error 3
kill: Could not kill pid '138': Unknown error 3
interface wlan0guest does not exist!
kill: Could not kill pid '159': Unknown error 3
interface vlan2 does not exist!
send[L2 Update]: Unknown error 100
device wlan0guest is already a member of a bridge; can't enslave it to bridge br
guest.
guest.
guest.
guest.
SIOCGIFFLAGS: Unknown error 19
guest.
guest.
guest.
guest.
guest.
RTNETLINK answers: Unknown error 2
guest.
guest.
guest.
guest.
guest.
interface wlan0vwn1 does not exist!
interface wlan0vwn2 does not exist!
guest.
device wlan0wds0 is already a member of a bridge; can't enslave it to bridge br0
guest.
guest.
guest.
apconfd: Stopping SNMP agent
apconfd: Starting SNMP agent
apconfd: Initialization complete.
Failed to get mac address of wlan1
PTX9160CZSKTEAM login: admin
o 07.03.2006, 15:53 | clown | Upraveno: 2006-03-07 15:56:30
foto k příspěvku  od clown
o 07.03.2006, 15:56 | clown
kuwa .. to je OKNO :o)))
o 07.03.2006, 15:57 | clown
furt nevim, z ceho ukradli ten druhej xicht web rozhrani ...
neco mi to pripomina ... ale zaboha uz nevim co ..
o 07.03.2006, 15:58 | michal_smsmsm (A)
wow ten log mi primomina muj firewall :)))
jinak ahlavne privez jeden kus k nam, at si to taky prohlidnu ;)
o 07.03.2006, 16:03 | clown
je to hnus .. je v tom Atheros B/G radio ... minipci ..
desny ..
i to Cisco by bylo lepsi ...
o 07.03.2006, 16:13 | michal_smsmsm (A)
jo zeptej se Detlefa jestli nema jednu 350ku nahradni :))
o 07.03.2006, 16:24 | clown
Detlef nema ..
Jan jich ma na stole asi 80 :o)))
nejaka lokalni firma konecne prisla na to, ze wifi je jim na houby a ze nepojedou po wifi ... :o))
o 07.03.2006, 16:28 | michal_smsmsm (A)
no super :) nechtel by ti dat jednu sebou na cestu :))
o 07.03.2006, 16:40 | clown
ne .. kuwa je ma ocislovany .. prelepeny atd ... :o)))))
o 07.03.2006, 16:41 | michal_smsmsm (A)
:)))))) kuwa az ja zjisim kdo mi stipnul tu moji... njn co se da delat...
o 07.03.2006, 16:57 | Daryl (A)
ty picoooooo :)))
o 07.03.2006, 17:02 | michal_smsmsm (A)
jo a do Cherry nejedu :) honza nejdriv mluvil s nekym kdo na to desne spechal a potom s nekym kdo rikal ze jim to staci zacatkem next week :)
o 07.03.2006, 17:04 | clown
Daryl ..
nooo .. podobne sem to tu nazval ja ..
pak jsem mel to prelozit do angliny .. :o)))
o 07.03.2006, 20:30 | Yawor
čínština, to já poznám....
Stránka vygenerována za 0.3346 sekund.
