Forum > Ostatní > Bluetooth do AUX v autě
 o Navštíveno 8131x o
o 09.10.2017, 11:50 | War
Chtěl bych se zeptat, zda někdo řešil jak streamovat hudbu do repráků v autě, které má starý infotainment.
Mám v autě AUX, kde mám aktuálně kablík a 2x 3,5 jacka, zapojím si tam telefon a funguje to. Tohle mi Apple vezme, protože nebude mít vstup na sluchátka.
Začal jsem hledat bluetooth krabičku, která by to nahradila.
Požadavky:
- ne s mikrofonem (chci to mít schované v loketní opěrce)
- podpora AptX
- aby to fungovalo i při nabíjení
Stačil by mi bluetooth receiver, ale všechny mají mikrofon, takže jsem našel receiver/transmitter, což je asi zbytečně drahé, ale nemá mikrofon. Nějaké lepší návrhy nebo zkušenosti?
TROND 2-in-1 Bluetooth V4.1 Transmitter Receiver / Wireless 3.5mm Audio Adapter (aptX Low Latency for Both TX and RX, 2 Devices Simultaneously)
Bluetooth Transmitter Receiver with aptX & aptX Low Latency. Powered by premium CSR8670 chipset, TROND BT-DUO supports the latest Bluetooth V4.1, whereas most of others on Amazon are V4.0, V3.0 or even V2.1. With aptX, you can enjoy CD-quality sound wirelessly over Bluetooth connections with aptX-source devices like TV’s, phones or tablets; with aptX Low Latency, you can now watch video while listening to wireless audio in a synchronized fashion AND without any noticeable audio delay
Bluetooth Transmitter with aptX Low Latency & aptX. TROND BT-DUO can help transmitting stereo audio with unnoticeable audio delay from your non-Bluetooth audio sources such as TV, MP3, CD player, PC, Nintendo Switch/3DS or Sony PS3/PS4 to your Bluetooth-enabled headphones, speaker or receiver. This way, you can enjoy high quality music wirelessly or listen to late night shows without disturbing your loved ones while they sleep
Bluetooth Receiver UPGRADED with aptX Low Latency & aptX. Previously TROND BT-DUO only supported aptX LL & aptX in the transmitter mode, and we have just added aptX LL & aptX into the receiver mode as well. Now you don’t have to pay high premium to get aptx LL-enabled wireless headphones or speakers; instead, your wired headphones or speakers can be easily turned into wireless audio devices with low latency
Dual Stream & Multipoint. When used as a Bluetooth transmitter, TROND BT-DUO can be paired to two Bluetooth Headphones or speakers, and streams audio to both of them simultaneously. Working as a Bluetooth receiver, it can still be paired to two of your smartphones or tablets, but the receiver can only receive the audio from one of the two paired devices. Please note that TROND BT-DUO only supports the codec of SBC when paired with two devices simultaneously.
What You Get: TROND BT-DUO 3.5mm Bluetooth V4.1 Transceiver with aptX Low Latency, USB to micro USB charging cable, 3.5mm male to 3.5mm male audio cable (50cm long), 3.5mm female to RCA male audio cable, Welcome Guide, 18-MONTH TROND warranty & 30-DAY money back guarantee
Stránka vygenerována za 0.6243 sekund.
