Forum > Ostatní > BMW X3 2004
 o Navštíveno 4761x o
o 14.01.2015, 04:20 | Tichy
Vcera jsem na BMW X3 odpojil baterku od plusu a vymenil vstriky. Po pripojeni baterky zpet nastal problem s ovladanim el. oken a zrcatek. Okna jdou ovladat jen obcas a to tak,ze se okno otevre cele a potom nejde zavrit uplne, nebo jen cukne. Zrcatka se chovaji podobne. Po zmacknuti tlacitka vyjedou do nejake krajni polohy nebo se vubec nepohnou. Pri zarazeni zpatecky bezproblemu najedou do prednastavene polohy. Jsem si temer jistej,ze problem nastal kvuli odpojeni baterky, ale ted nevim jak vsechno vratit do normalu? Nevi nekdo? Budu vdecnej za kazdou radu.
o 14.01.2015, 08:01 | CervinVega | Upraveno: 2015-01-14 08:06:35
v manualu nic nepisou? musis nastavit krajni polohy, mam pocit, ze musis drzet "dolu" 10s (okno zcela dole) a "nahoru" 10s (kdyz je okno zcela nahore)...
---edit---
Initialisation
Following replacement of a power window motor or a door module and following every repair to the power window mechanical system, an initialization must be carried out. The initialization serves to adapt the anti-trapping protection to the power window system. The initialization procedure is divided into the functions standardization and learning the characteristic curve.
In the case of standardization, the mechanical end stops of the power window are learned.
In the case of learning the characteristic curve, the mechanical closing forces in the power window are recorded.
The initialization must always by run with the power window switch on each door!
Control procedure for initialization:
Press the window 'open' switch beyond the second switching position. When the window has reached the lower final position, operate the switch for at least 15 seconds but not longer than 25 seconds.
Then let go of the button and immediately pull the switch beyond the 'close window' position. Do not let go of the switch!
The window now moves into the top final position, stops, then moves to the lower final position, stops again and then moves back to the upper final position. The switch must be held in the "pulled beyond engaging point" position during the entire procedure.
Once the window has reached the upper final position, the initialisation is complete.
Important!
It must be ensured that there is on-board supply voltage of at least 12 V during initialisation, otherwise initialisation of the power window is not possible.
The anti-trapping protection has no function during the entire initialization procedure.
Emergency operation
If there is no valid characteristic curve, the one-touch closing function is unavailable. If there is no standardization, the Automatic Open function is also disabled. In this case, the window only moves around 2 cm in the desired direction with each press of the button.
Stránka vygenerována za 0.4244 sekund.
