Forum > Ostatní > Reset oleje Mondeo MK III 2007
 o Navštíveno 3070x o
o 15.05.2012, 16:21 | SEKIN
Není na to nějakej postup, klikání na čudlíky a rumplování s klíčkem nebo nějak? Gůgl ani jútjúb jsem nic nenašel.
o 15.05.2012, 16:24 | Lukasino
Tady něco je pro 2008, ale to nevím jestli už není mk4
To reset your service light --
Get in the vehicle - ensure all doors are closed..
The switch the Ign ON..
Then press both the accelerator AND the brake pedal and HOLD them down for a minimum of 15 seconds -
Then press the "OK" button ( in the centre of the little square toggle switch arrangement ) ...
The service light will then go out when the system is reset..
Release the pedals and switch the ign Off.
Read more: [ Link ]
o 15.05.2012, 16:26 | Lukasino
Tak by to mělo šlapat, tady další dotaz, stejná odpověď...
o 15.05.2012, 16:32 | SEKIN
Zrovna tohle jsem taky našel, ale nefugovalo to.
o 15.05.2012, 16:40 | Lukasino
Tohle jsi četl?
"The procedure states that when the oil change reminder turns off "this confirms that the reset procedure has been correctly completed". What actually happened on my 58 plate Zetec 140tdci was that the reminder message disappeared after about 5 seconds and the normal display returned - but you have to keep your feet on the brake and accelerator pedals for "a minimum of 15 seconds" after that before another confirmation message appears. It is this latter message that you want to see.
So, if any of the rest of you have tried this and failed because you didn't keep your feet on long enough, relax in the comfort that you're not alone. The procedure works - if you do it right - Duh !!!! "
o 15.05.2012, 16:41 | johanik
se sem vtírnu, nevěděl by někdo na Fiat Ducato 2006 ? :-) taky jsem lovil a nic :-) díky
o 15.05.2012, 16:43 | dj.DEKL
Zmáčkni a drž brzdu+plyn, zapni klíček na kontrolky a čekej... 20-30sec :-)
o 15.05.2012, 16:44 | Lukasino
johan
"quick push on the button switches between them, but once you've got the one you want, hold the button down (it says at least 5 seconds)"
NEBO
Minuta na Googlu... :-P
o 15.05.2012, 16:48 | SEKIN
Tak už to je. 15 s fakt bylo málo čekal jsem dýl a v pohodě. Díky Lukasino
o 15.05.2012, 16:48 | johanik
tak to jsem zvědav, dikes :-)
Stránka vygenerována za 0.4097 sekund.
